Sea toilet installation help required
Windway
Active Member
25 Aug 2012
Porthmadog
My Orvea Italian sea toilet has black waste hand pumped via a reinforced plastic stainless spiral waste pipe to deck level with breather then big loop to stand pipe welded into hull above waterline and sea cock to close. Seems a proper job, but I wonder should there be a non-return valve fitted in the black waste line, in case the seacock failed?
Does anyone know, can anyone advise me and if so can you recommend a suitable NR valve to use in this application?
The seacock failing is no different to the seacock being left open - in neither case will the water suddenly jump up the pipe to deck level to get over the loop and flood into your toilet. The pump already contains a one-way valve, otherwise it would be a mere poo-stirrer rather than a pump.
By the sounds of it you already have a solid and well-engineered system; leave well along. An extra valve with moving parts will just encourage blockages.
Thanks Pete
