dulcibella
The GPS antenna/receiver unit on my 1996 vintage Raytheon/Autohelm Sea Talk system has failed (dome cracked and water ingress). Any suggestions on a currently available and compatible unit would be gratefully received!
If you want to stay with seatalk it has to be Raymarine.
The early "autohelm" "black box" GPS unit which I have, and also I believe the following "raytheon" unit actually only put out nmea 0183, relying on something else to translate to seatalk: either a navdata unit or in my case an st50 navcenter. Assuming that part is intact, nmea version incompatibilities aside (I'm guessing a simple GPS should be ok but stand to be corrected by those more knowledgeable) a unit outputting nmea 0183 might be fine.
Dulcibela: Do you know which unit you have, what it's connected to and/or what it outputs?
Personally I prefer a gps unit with a small B &W screen. It will then work independedenty from the chartplotter. Good for redundancy and if you want low power like for an anchor watch.
It's an all-in-one unit called the "SeaTalk GPS transducer" - just says GPS on the dome but manual describes it as having a built-in SeaTalk interface. The wiring diagram shows it as having 3 wires (yellow, black and red) in the cable, which connect into the SeaTalk system through a simple junction box. Data output is "NMEA 0183 sentences to SeaTalk interface". The other instruments in the system are ST50 and a ST4000 autohelm (which won't work at all without the GPS input).
If you are really stuck and have to have a Seatalk one I'll do a YAPP and make you one. Serial GPS tansducers can be got for about £25 (Globalsat BR-355 being an example) and they work inside the cabin on a GRP boat. The NMEA to Seatalk bit will just be a rehash of previous YAPPs.
SAMYL is being misleading with his post. If you can only connect a Seatalk transducer to the rest of your system a NMEA one will be no good.
I was suggesting replacing the gps bit not the transducer.
This will be a basic question for the cognoscenti but a couple of days googling buck converters and looking at the stwitched mode wares of farnell and RS gives me too much info so I need to ask...
What's the most appropriate way to step down from 12v (boat batteries) to 5v, smoothing out any transient drops when the fridge turns on etc. in order to power a device like the one mentioned above? I'm hoping for something which will cost rather less than what it would be powering (and I don't have a spare 12v phone charger kicking about to hack)
I've used one of these..
http://uk.rs-online.com/web/p/linear-regulator/5164799/
You'll need a heatsink...
