When you unscrew lid (to check strainer is not clogged) there is a big rubber seal… the bronze screw you unscrew always had this very insubstantial tiny yellow metal washer… this broke in half the other day - and so I need a new one I think… it seems water may be leaking from the strainer… where this washer was (a tiny rubber washer just squashes and breaks up when I tried using it). Maybe the washer is not necessary…Sorry, photo is so out of focus I cannot even see what you are talking about.
Still… I would like to buy some new ones but not sure what they are called! I will have to use SVB.Sorry, photo is so out of focus I cannot even see what you are talking about.
Would silicon bronze be better.? Arthur Beale say brass is next to useless at sea !I assume from the colour that it is brass.
Yes, underneath the butterfly nut! I had a brain freeze when I wrote original question lol. It is a tiny little washer - very insubstantial looking.Do you mean the washer under the 'butterfly' nut which secures the lid ?
That is good to know! I thought it may be bronze.I assume from the colour that it is brass.
Many thanks for this info… the previous washer was metal but looked like it had a yellow coating… I think the smallest washer there would be too big but will measure butterfly nut to make sure.Would silicon bronze be better.? Arthur Beale say brass is next to useless at sea !
Silicon Bronze Washers
In a non-critical role like that I don't think composition is very important. Brass washers are usually 70/30, so not very susceptible to dezincification but as VicS points out silicon bronze or even copper would be as goodThat is good to know! I thought it may be bronze.
Presumably that must be a water tight joint.In a non-critical role like that I don't think composition is very important. Brass washers are usually 70/30, so not very susceptible to dezincification but as VicS points out silicon bronze or even copper would be as good
The last washer was not Dowty. Those silicone bronze look good. Not sure if it was ever water tight (in my ownershipPresumably that must be a water tight joint.
Would a soft copper washer be better
or a Dowty washer
or should there be an O ring in a recess plus the brass or bronze washer .........??
