sheppard
Active Member
The conical tap in one of my Blakes sea cocks has an eroded ‘pit’ opposite the hose input. The sea cock seems sound, not a drip leaking, as the topmost half cm of brass is sound (and this top rim is the bit, the brochure says, which keeps the ocean out).
When I asked in chandlers about a new conical insert, they sucked air through their teeth, shook their heads oh-so sadly, and generally looked at me as though a flock of seagulls had roosted on my head for a week. They sold only the set, with the outer sleeve that is set into the hull, because they match each other, apparently. In other words, instead of a £40 inner cone, they sell the whole unit (£100, which is ok), but which means a lift out, cutting out the old sleeve, fibre-glassing and so on, adding a zero to the cost and making a big deal out of what I thought was a simple replacement.
Anyone had experience with fitting an inner cone only? Did the fact that you had a non-matched pair cause a problem, as in water moving inwards, boat moving downwards, and so on?
