Bradders
The intake ports on the SD50 keep getting blocked, I have disconnected the hose entering the raw water strainer and have pumped air down the raw water inlet hose to clear any blockage which works for a time. I had a generator installed a few year ago which has a raw water inlet, can anyone see any reason why I couldn’t use the generators raw water inlet to feed raw water viar the water strainer to the cooling system of the yanmar 4JH4CE engine and bypass the SD50 intake ports. I would not be able to use the engine and generator simultaneously which is fine and would only use this system as a back up raw water inlet - the boat is being hauled out shortly to have the hull power washed which will hopefully clear the sail drive intake ports, but for how long I’m not sure
Thanks in advance
Thanks in advance
