Scuppers, Whats your take on them
steveeasy
12 Aug 2014
Quick one this. Do they exist on a sailboat. Ive heard the term used widely by owners. some people refer to cockpit drains as scuppers, not sure about that. I heard the term used for drains from a bridge deck to the cockpit sole. not sure about that. So I had a read and this popped up a hole in a ship's side to carry water overboard from the deck. Made sense to me. A couple of my friends boats have these instead of normal deck drains.
Whats your Take on them.
Steveeasy
Poignard
23 Jul 2005
South London
"SCUPPERS, dalots, (schoepen, Dutch, to draw off) certain channels cut through the water-ways and sides of a ship, at proper distances, and lined with plated lead, in order to carry the water off from the deck into the sea.
The scuppers of the lower deck of a ship of war are usually furnished with a leathern pipe, called the scupper-hoase, which hangs downward from the mouth or opening of the scupper. The intent of this is to prevent the water from entering when the ship inclines under a weight of sail."
Ref: Falconer's '
An Universal Dictionary of the Marine
Or, a Copious Explanation of the Technical Terms and Phrases Employed in the Construction, Equipment, Furniture, Machinery, Movements, and Military Operations of a Ship. Illustrated With Variety of Original Designs of Shipping, in Different Situations; Together With Separate Views of Their Masts, Sails, Yards, and Rigging. to Which Is Annexed, a Translation of the French Sea-terms and Phrases, Collected from the Works of Mess. Du Hamel, Aubin, Saverien, &c. '
Blueboatman
10 Jul 2005
My last boat had two scuppers at the front of the cockpit .
And a much larger dump drain or ‘scupper’ at the rear . Seemed sensible
With an open transom this comes as standard ?
steveeasy
12 Aug 2014
Ref: Falconer's '
Ok thanks!!
steveeasy
12 Aug 2014
The cockpit sole could reasonably be considered as a 'lower deck', in so far as it is a deck lower than the maindeck.
So, applying Falconer's definition, its drains are 'scuppers'.
Henceforward, I shall refer to my cockpit drains as 'ye cockpitte scuppers'.
Oh. Right that opens up a can of worms den.
thanks
Steveeasy(y)
johnalison
14 Feb 2007
Essex
My HR has a modest toe-rail with a teak cap. The water drains off via two pairs off scuppers that join the cockpit drains. The advantage is that you don't get grey stains on the topsides, but risk having the scuppers blocked with leaves, though this has only happened once and was easily remedied.
Tranona
10 Nov 2007
Are they related to being “scuppered”
Yes - as capnsensible says, and immortalised in the shanty
"put 'im in the scuppers with the hosepipe on 'im"
Then carried over into everyday usage to mean something like all is lost, as in Boris yesterday - he was "scuppered" by the metaphorical hosepipes of his colleagues' declarations of lack of support!
Poignard
23 Jul 2005
South London
Good heavens Tranona, I never thought I'd see you post anything like that!
The world is being turned on its head.
Tranona
10 Nov 2007
Indeed it is. Just trying to find a topical way of explaining how expressions enter from specialised to everyday language. The subject of that example will no doubt be the source of many new expressions as he slides into history! Just thinking of all the quotes (and misquotes) of one of his predecessors that still hang around in our everyday consciousness.
steveeasy
12 Aug 2014
By the way…’scuppers’ are not what are now called ‘freeing ports.
So are they actually Freeing ports, and scuppers nothing more than a dark place for drunken sailors to hang out.
Steveeasy
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Perhaps if you have deciduous cross-trees?
Landfall
4 Jul 2020
Beautiful south
Three inch toerail with teak capping makes 4.5 inches 40 foot on deck, beam 12 .5 feet , double ender , let’s call it 4 x90 degree triangles 6.25x20x.33 approx so 41.25 cubic feet times 4 = 165 cubic feet
avoirdupois weight of 1 cubic foot of water is62.43 pounds . If I took a big green over the deck I would have. 10300 pounds of water on deck . Or 4.29 tonnes . Yep I need my scuppers or a return ticket from Davy Jones locker
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Is your deck flat, like a ro-ro ferry car deck?
