MapisM
Premise: boat sheltered and wintered, engines expected to not move for 7 months overall.
Suggestion received from an official engineer (MAN as it happens, but I don't think this matter): every month or so, rotate the engine manually, in order to not leave the very same valves open/close for the whole timeframe (changing also the raw water impeller position, as a by product).
Note: You are allowed to comment on whether the suggestion makes sense or not, but only as long as it's not an excuse to avoid the real questions
, which are...
1) By how many degrees should the engine be turned, in order to be sure that all valves which were previously open will close, and vv?
2) Should the engine be rotated CW or CCW (looking at it from the belts side, not the gearbox side)?
3) Does it matter whether the engine is rotated in the right direction anyway, since it would just be rotated manually and very slowly?
Of course I know what I was already told on the above, but don't ask me to spill the beans in advance...
I'm just not 100% convinced of that, so I thought that rather than squeezing my own head further, I could as well make some forum brains smoke...!
