what is the model?
16M, 14M, 20M
if its this age will be surely wood
still very nice Yachts IMO
check also for Canados, Versilcraft, Tecnomarine, Lavagna Admiral, and Pisas of the same age and type
IMO all look nice but San Lorenzos still has something more on the looks department
if you are interested I have a Canados 60 which might go for cheap
thanks for the info.
looking at 16 meter. (57 ft) wood. 1978 model. seems lovely but worried bout engines. may need work on them or replace.
regards. james.
I worked on a cruise-boat (20 metres) with twin 8/92's, running 115 injectors, claiming just under 700 HP each. Wasn't that bad on fuel, good service life, but I don't think they like long periods of low revs, they need to work.
Agree... all DD two strokes enjoy themself best under load ... and perhaps even above 50% load....
You can run them low... but best at about 11 - 1200 (just before the turbo kicks in) for long periods as long as you get the temperature up... What they do not like is idle and "no load". They will also be "thristy" at idle compared with a modern 4 strokes as there are more mechanical parts (and friction) to move around.
