William_H
I love to race my little boat which means lots of up wind sailing against other boats. To me that makes it a sport. Yes I know some on this forum say "gentlemen don't sail up wind".
Anyway my friend Jim asked for advice on sailing up wind faster. Particularly helming. He has a typical 30 ft fin keel boat. Here is my advice. He certainly improved a lot yesterday and I thought perhaps others might benefit. or perhaps it is just obvious.
Anyway I suggested he monitor his speed on GPS. (water speed would be just as good.) when sailing hard on the wind.
You need to relate the speed to your angle to the wind. If you have plenty of wind so the boat can easily reach hull speed (About 20% more than square root of water line length in feet.) then you need to sail up wind at a water speed a bit less than hull speed. If you find yourself going too slow then you must be pinching too close to the wind. If you find your self meeting hull speed then perhaps you are not pinching close enough to the wind.
The boat can not exceed hull speed without serious amount of push power. This push power can only come from not sailing close to the wind. So far better in going for a windward point to sacrifice some of that push power and speed for pointing higher.
All this assumes you have plenty of wind and you have the right sized sails correctly set for beating. Once you get the feel for the correct speed then you can just concentrate on sail actions (luffing) to keep up with wind shifts. Just keep checking that speed. Of course the best way to measure and improve your helming on the wind is with a similar boat next to you going to the same place. ol'will
