Nauti Fox
I don't know if this has been posted here, sorry if it has, enjoy it if it hasn't....
Looks like someone hid the razor for sure.I lasted about 10 mins with this channel. Don't watch it after drinking even a small gin and hide the razor blades.
And there's me thinking that steering the yacht for hundreds of miles using a drogue was pretty impressive.....Looks like someone hid the razor for sure.
I'm delighted to hear it. Just not my cup of tea.Looks like someone hid the razor for sure.
We do. On my boat it's one of the V berth bunk boards and the spinnaker pole.I've never understood why long-term blue-water cruisers don't routinely carry an emergency rudder.
It's not really different from mobo owners carrying a second, get-me-home outboard.
Of course you have tried it in F5 off shore haven't youWe do. On my boat it's one of the V berth bunk boards and the spinnaker pole.
All you need a rudder for is for a fast or significant change of course. Steering can be done by the sails, trailing warps or the sick bucket off the transom. You have tried this in a F5 offshore haven't youOf course you have tried it in F5 off shore haven't you![]()
My V bunk board has a greater surface area than my rudder and there is a lot of stuff onboard to jury rig a 'steering board'...
Rigging the day and night signals for not under command would be more of a challenge. I shall need to give that some thought.
The kit is onboard for the steering board. It's the NUC night signals that is the problem. I can use the two bits of the mooring ball and some stuff for the day signal.So you've already dealt with the minor 'challenge' of keeping your bunk/steering board attached to the spinnaker pole then?
So it is all cloud cuckoo land theory & you have NOT tried it.All you need a rudder for is for a fast or significant change of course. Steering can be done by the sails, trailing warps or the sick bucket off the transom. You have tried this in a F5 offshore haven't you.
Why do you keep reffering to part of the english channel, the solent as a lake? Its not even close .Lake Solent
Where did you try your system out? Offshore in a big ocean swell and moderate winds or what?We rigged an emergency rudder using one floor board and the spin pole. The floor boar was prepared - it had holes in the 2 forward corners which led to either side of the transom and we had two U bolts that fitted round the pole, holes prepared in the floor board. The board was marine ply and fairly robust. I'm not sure why anyone would think that 2 well fitting 'U' bolts would not hold a bit of ply to the spin pole.
We did try it and did work surprisingly well. The ropes in the corners kept the board roughly vertical and steering itself was accomplished b y simply pulling the spin pole port and star board. It was not much use for large and rapid changes of course - but as Sandy said - if you are aiming at 'land' you can worry about the fine tuning of course when you get there (or get a tow). Its a bit of a faff as you need to adjust all the lines - but what else are you doing?
A bucket needs to be steel, gal or stainless - or its useless and will collapse (and simply increase the amount of plastic pollution in the oceans). You could carry a small drogue - but it will slow down your passage - and you might run out of food and water
However its all a bit academic - under what conditions are you going to loose all of a modern rudder without it causing major issues to the integrity of the yacht. I can see you losing part of the rudder (and causing no other damage) but the whole rudder - I'm sceptical. If the rudder blade collapses then most rudder stocks have splines - specially devised to allow you to tie/lash a prepared board - though not easy, or even possible, unless its calm.
But whilst it is a bit of a nightmare scenario - its a bit like life rafts and LJs - how many are actually deployed in anger how many rudders are lost (and why not carry two 'U' bolts). Steering fails - but that is a different issue - and solution. We had ours fail twice - the AP ram works independent of the wheel - simple. The first failure was the cable failing the second the casting for the sheaves collapsed - why do they use cast aluminium for the sheaves housing in contact with steel cables?
Jonathan
Simples - It is a well sheltered area that offers wind and a smooth sea even in a F8, just like a lake.Why do you keep reffering to part of the english channel, the solent as a lake? Its not even close .
I believe some orcas are getting quite good at dismantling them!However its all a bit academic - under what conditions are you going to loose all of a modern rudder without it causing major issues to the integrity of the yacht.
Not out for a fight - just curious.
I think I am right in saying that the Solent is not classed as "open water" (hence no passage plan required) therefore, not part of the English Channel, hence the derogatory term lake.Why do you keep reffering to part of the english channel, the solent as a lake?
