Saildrive s120
gerry ledger
New Member
19 Mar 2020
essex
I have bought propeller that is the wrong hand can I reverse the gear change as the ratio s seem to be the same and the thrust is in the leg it is a Volvo 120S
You probably can simply run in reverse, although that would not be my preferred solution. I suggest that you speak to/email Volvo Penta and seek their advice.
Richard
I cannot see any obvious reason why not. Diagrams of power flow from 'shop manual
Now changed the diagram on my previou post... managed to snip the wrong one previously
Now wondering if the design of the lower gears will dictate which way they should normally run
