EugeneR
Hi all,
I’m considering buying a semi-custom 50–55ft cruising cat from the 2010s, currently in a remote location in South America.
We plan to keep her 5–10 years and are budgeting accordingly e.g. a rigging inspection recommended replacing the original standing rigging, which we're taking on (at our own cost).
One area of uncertainty / concern is the aluminium sail-drives:
- A prior survey for the current owner’s purchase in 2021, noted the drives were coated with the same antifoul as the hull, and warns about possible copper / galvanic corrosion. The survey also noted poor quality hull preparation.
- The owner believes there is an epoxy barrier under the antifoul.
- The boat has not been antifouled since remediation of the poor quality hull anti-foul application later in 2021. The owner says he plans to do a new bottom job this season.
- I asked about sail-drive seal history (boat approaching ~15 years). The owner said he replaced “lower-end o-rings/seals” himself during a recent haul-out, describing it as “an easy job, not very technical”. It’s therefore unclear whether this refers only to prop/leg seals or includes the drive-to-hull diaphragm, and there’s no yard documentation.
- Before sale, the owner plans to “tidy up” the sail-drives (e.g. epoxy fairing and "maybe something proper like PropSpeed") alongside a bottom job, which could make survey inspection harder if there’s any pitting.
My concern is the combination of infrequent antifouling (and by inference, inspection), possible coating incompatibility with risk of localised pitting/corrosion if the epoxy barrier has degraded over the ~5 years, uncertainty over the hull/drive seal replacement (it's late in the game to ask), and the risk of cosmetic remediation before a buyer's survey.
Given that mix, what would you do in practice?
- Insist on specific inspection steps e.g. stripping back in places? I won't mind a surveyor scraping off some anti-foul but how might they check the sail-drive integrity?
- Assume/budget for remediation - if that is even possible?
- Or, perhaps budget for full replacement and price accordingly? That would give long-term reliability - but I can't expect the current owner to cover all of that.
- Or walk away unless certain conditions are met before survey?
Any practical owner or surveyor experience would be appreciated.
I have an alternative lined up - but it's something completely different, so want to see if / how we can make this one work, first.
