emandvee44
I was re-fitting the shiny polished propeller when I noticed the paint/anti-fouling coating had broken down in several areas and in fact the aluminium was visible.
Therefore some treatment is required!
I did a search on the Forum and read all the threads on the subject, of which there are many, but could not reach a conclusion as to the correct procedure.
This is what I am planning to do.
Scrape off all the anti-fouling and original paint.
Rub down the bare aluminium with Aluminium oxide paper.
Apply 2 or 3 coats of epoxy primer*
Then apply an enamel top coat
When dry, lightly key the enamel and apply the usual spray on anti-fouling, something like mille drive (or whatever is available out here)
*The epoxy primer (Titan) is claimed to adhere strongly to aluminium and other surfaces, and therefore I do not think etch primer is necessary, and it is not mentioned in the surface preparation advice on the tin.
Any comments?
Thank you,
Michael.
Any comments?
Thank you,
Michael.
