Sail slides instead of luff tape into furler
zambant
25 Jan 2010
I have a MK4 Rotostay furler on my Centaur.
I have a Genoa which has hanks on it and am considering using it with my furler.
I am considering removing the piston hanks and replacing them with plastic sliders of the correct size to run up the foil. I'm going to use tape and sew hrough the centre to hold them.
My questions are .....
1. Has anyone else done / got this arrangement
2. If you do have this arrangement does the jib furl ok?
3. Any other comments / issues / observations
I realise a luff tape is the best way to go but finances dont allow for this...
Thanks.
John :)
C
catalac08
I have used a couple of old genoas & jibs like this. Both set and furled very well and there was no noticeable difference in performance from either. In the 3 seasons I used these there appeared to be no UV degradation to the sails or stitching that I could see. Good way of keeping sailing economically. I have never understood why people just bin perfectly usable sails-I think most people do not realise there is this option. I just used several turns of thin cord to secure the sliding hanks. If you work out the strain on each individual slide this is actually quite low compared to the total sheet loading.
ianat182
10 Jul 2008
,home Portchester
I did this job on the previous old genoa I had and it works well provided the slugs are the correct diameter for the furler slot; mine is a Colnbrook Seareef and I used nylon sliders of 5mm and a 'neck' of 2.0mm; these attached through the former piston hank eyelets by waxed, strong whipping twine. Furling was no problem and lowering the sail straightforward. I have a small red storm jib fitted with hanks which I am about to modify in this way,though have never had to use it yet.
ianat182
PuffTheMagicDragon
ianat182
That would only be possible if you have already removed the genoa, something that might not always be possible. If the genoa is furled the groove would not be available.
I have an emergency forestay that attaches just aft of the furler and is tensioned by a Highfield (?) lever. The storm jib is bent to this stay with piston hanks. Hoisting is either by the spinnaker halyard or even by the spi-boom topping lift,which is mounted very high on my mast.
Tranona
10 Nov 2007
I am contemplating exactly this arrangement - will follow this thread with interest.
regards
David
Although it is a cheapskate way of extending the life of old sails, if you really want to get the best out of a furling genoa it should be fitted with luff tape, and, depending on cut foam padding on the luff.
Can't see any advantage of using slugs over tape if the sail is designed to be used on a furler.
oldharry
30 May 2001
Considered doing this, but decided the slugs would prevent the sail from rolling properly, and could cause a lot of local stress on the cloth, and prevent it furling properly. Or not. So I never actually tried it in practice. Would be interested to know whether I was right.
zambant
25 Jan 2010
- the cost !!!! slugs are a few pence each....:)
Tranona
10 Nov 2007
You get what you pay for! If it were a satisfactory way of attaching sails to furling foils, everybody (including sailmakers) would use them - but they don't.
As said, it is a a cheap way of reusing sails designed for another purpose.
aquaplane
16 Sep 2006
West Yorkshire
www.utilitywarehouse.co.uk
I bought a boat with a recently fitted roller furler and that used the old genoa with the piston hanks replaced with slugs as described previously.
The luff was too long to fit the furling gear so that needed rectifying.
There was no sacrificial strip either so I had one fitted. Cutting the luff down and fitting a tape plus the sacrificial strip cost £350 IIRC, it needs to be a good sail to spend that sort of money on it.
The sail wasn't designed to roll up so I used it as a roller furler not roller reefing, ie all out or all in.
neil_s
28 Oct 2002
Chichester
I found the old hank-on working jib converted to roller reefing so useful I have just ordered a new sail.........to be fitted with slides!
Neil
Old boat old ropes
22 Sep 2017
Hi there. I'm thinking of doing the same with sail slugs. I'm not sure the drum is working correctly as it appears the furling system was cobbled together from a few different systems (all selden furlex). The groove in the foil is 6mm does anyone know where I can find 5mm dia sail slugs? Thanks.
