Sail Cleaning
Article a few months ago in november PBO
Hitech automated process by Novosail, Hedge End, Soton £6.08 per kg + VAT including anti UV and anti fungal treatment.
Manually by Tip Top but who only take from sail makers etc not direct from owners.
Ave price quoted as around £4 per kilo excluding any treatments.
I have just had my No1 done at Novosail. Haven't seen the end result yet as I will be collecting next week, I think. They have a big "machine" to wash and clean the sails. Most others as I understand it are pressure washers then hung in a loft to dry. (But please correct me if I'm wrong)
Very helpful and friendly lot. Some discounts around for various owners associations etc.
Will happily report back what the sail is like as it was quite dirty and had some mildew between the laminate overlaps at the seams.
no chemicals please
low pressure, like the garden hose. Gentle scrub with soft brush. Air dry. That's it. Anything else wil shorten life of the sail, remove dressing, bad news
IMHO
I have just had my No1 done at Novosail. ........ Most others as I understand it are pressure washers then hung in a loft to dry. (But please correct me if I'm wrong)
I do hope no-one is knocking the stuffing out of their sails (or teak decks, or canvaswork) with a pressure washer. It does them no good, you know.
IMHO
According to the PBO article Tip Top spread the sails on a purpose made, slightly sloping floor, apply the cleaning agents with a watering can and brushed gently with a soft bristled broom. Rinsed turned over and the other side done the same. A pressure washer is used on a low setting for rinsing off.
They are dried quickly (overnight) to prevent mould regrowing.
I can certainly recommend Novosail - I have used them for 2 years now via our local sailmaker JKA Sails in Pwllheli, and the result both times has been the proverbial "like new"
