Sail clean and sail numbers - Gosport
wizard
24 Jan 2003
Portland
Can anyone recommend where I can get my mainsail cleaned and have the sail numbers put on in the Gosport area for a reasonable price.
Coastal covers in Gosport did mine for a competitive price and good and quick service (picked the sail up from the boat etc).
Google and you should get them-they are in Clarance Marina.
No connection etc.
do the sail numbers yourself.... it's not hard order from kyrospruce. numbers and letters are about £2 each and self adhesive just make sure you stick them on using a hard surface behind !
costal covers as stated above at clarence now owned by arun sails I think for the cleaning! or google tip top sail laundry in portsmouth or Novosail and cut the middle man out /forums/images/graemlins/grin.gif
For the cleaning process I use a local Launderette in the Precinct next door to Dominos Pizzas off the Avenue in Gosport. They are excellent and have done my five sails several times and have industrial size machines, at good prices - you collect a couple of hours later
As recommended elsewhere, I'd recommend going through Arthur's Chandlery for your sail cleaning. A company called 'Tip Top' do the cleaning for most of the sailmakers and chandlers in the area but won't deal with individuals. The cost, per Kg, of going through Arthur's was a little more than half of what some of the big name sailmakers were charging to use Tip Top through them.
