They are reputedly bomb-proof, so more a question of whether you can get all the gear on you want to take. Would probably be more inclined to look for the shallow fin version, personally.
Hi Tigawave
we've had the boat (a 29) about 4 years- as usual we keep spending/upgrading - in another 4-5yrs should have more time to maybe have an adventure
we are safety conscious but quite minimalist
i would still want a new engine/a windvane/ etc even though set up at the moment is fine-
rigging is due to be replaced - i think standard is 7mm- is it worth going up a size- comments anyone please?
usual dilemma ! throw more money at her or upgrade slightly-vancouver 32?
thanks every one for the comments so far
I had a fin-keel 29 for 14 years and did a lot of Channel & North Sea crossings very happily. However, the boat is fairly high-sided with a tallish rig and though no more tender than she should be, does need sail-shortening earlier than, say, a Sadler 32, around upper force 4 to windward. Again, the motion is what one would expect from a fairly high-volume boat with a shortish waterline and I would expect it to be a bit wearing on an ocean trip.
Internally the boat works well, once you get used to the odd companionway steps, and you can make two or three good sea-berths. The galley was always a weak point, but though small is safe & practical, though most were supplied with Vanessa cookers without flame-failure burners. In spite of the foam construction, stowage is quite good and I used to sleep in the quarter-berth with two bikes at the end of the bunk.
