Wandering Star
Hi,
I’m unable to visit my Sadler 25 for a couple of weeks and wondered if anyone could help with dimensions, advice or suggestions regarding the stern gear? I haven’t owned her long so I’m not entirely sure what her sterngear and shaft measurements are - or even how accessible they are although I have noticed there’s a screwed down cover under the cockpit grating which presumably allows access to the sterngear!
Currently, she’s fitted with a PSS shaft seal which appears to be leaking/dripping. On a 3 hour passage under engine (Yanmar 1GM10) the bilge space under the engine contained about a gallon of water. But after leaving the boat on her mooring for a couple of weeks there will also be about a couple of litres of water in the engine bilge.
So I suspect the PSS shaft seal is leaking although I haven’t actually investigated the source of the leak properly.
I have no idea how old the PSS seal is so was thinking of purchasing the full service kit and fitting this but I need to identify the shaft diameter and Stern gear diameter in order to buy the correct sized service kit.
Also, I’d like peoples opinions on whether the work can be done with the boat in the water!!
Any advice or opinions gratefully received.
