sabresailor
Hi - can anyone compare the sailing abilities of these 2 boats - speed & windward sailing?
Cheers
Mike
Cheers
Mike
Some friends at my club had a seal 28 for many years and cruised her far & wide inc S Brittany and twice through the French Canals.
I have no real experience of Sabres apart from sailing past them, I get the idea they're a good boat which will look after one but the keels are low tech and draggy - the Seal would be faster on all points of sail, particularly to windward.
A good sailor I know reckoned the Seal 28 is a bit hard mouthed to steer, due to the long ballast stub, but I'd still expect handling to be better than a twin keeler.
The Seal is also very much roomier, and the aft cabin not only keeps following seas off, it's a handy place to stow children / visitors or have a workshop.
If looking at any lift keel boat an inspection with boat hoisted and keel lowered is essential, as is a cradle or pit to allow maintaining the keel plate.
Cheers
Mike
Where are you going to be sailing?
A lifting keel, is much handier than bilge, should you touch bottom, & getting onto a mooring, when little water underneath, can be a godsend.
Does the Seal 28 (or any or the Seal / Parker range) - sit upright on a hard / sand bottom?
I have had a Sabre 27 and loved the ability to sit upright in drying harbours.
Mike
it won't sit upright, unless you fit legsI have a mooring on the Exe and love sailing in Brittany - so I'm keep to have the ability to dry out - but not sure if the Seal 28 sits upright.
Mike
Alant,
it would be interesting to hear why you put a raised eyebrows emoticon in reply to my perfectly reasonable post, other than the fact you lately reply with nonsense to anything I say.
Th only time a twin keeler is better for drying out than a lift keeler is when the seabed is a little rocky; for this reason I dislike boats with completely retracting keels which settle right on the hull rather than a ballast stub, even if the seabed is mud there will be the odd stone.
Deliberately drying out on a known rough / pointy seabed is not on for any keel type though.
For "I have no real experience of Sabres apart from sailing past them," yet another unconvincing claim for your speed machine!
PS
When did I mention "drying out"?
