beneath12
New Member
I'm trying to start a SABB 10HP engine on a narrow boat, but the starting handle won't turn over on compression . I'm an absolute novice , so please advise what I should check first
You're supposed to use handle with compression leaver in "off" position... build up rotational speed with handle with compression off and then throw the leaver the 90 degrees into its slot ... in effect using the inertia created to get engine past the first couple of compression strokes and thus ignition...I'm trying to start a SABB 10HP engine on a narrow boat, but the starting handle won't turn over on compression . I'm an absolute novice , so please advise what I should check first
