25 Jun 2022 #1 I Ian_Rob Well-Known Member Joined 31 Jan 2008 Messages 1,209 Visit site I have just lost the function of both of these instruments. Is there a recommended troubleshooting route…..?? They don’t seem to be receiving any power.
25 Jun 2022 #2 PabloPicasso Well-Known Member Joined 12 Feb 2010 Messages 2,945 Visit site Check the power supply, switched off, fuse blown/tripped out, wire disconnected somewhere. Have you carried out any other work that may have interfered with supply? Use a circuit tester see if there's power at the switch, then any junctions until you find the issue. Is a cable disconnected? Good visual inspection of suspect areas. Be methodical and you'll locate the culprit
25 Jun 2022 #3 E earlybird Well-Known Member Joined 18 Aug 2004 Messages 3,942 Location Cumbria; U.K. Visit site If you can get to the backs of the displays try pushing the connecting plugs firmly home. Give them a wiggle.
26 Jun 2022 #4 I Ian_Rob Well-Known Member Joined 31 Jan 2008 Messages 1,209 Visit site Thanks for the replies. It isn’t the fuses all are fine…….?
30 Jun 2022 #5 PabloPicasso Well-Known Member Joined 12 Feb 2010 Messages 2,945 Visit site Have you a circuit tester? Is there power present both sides of the fuse when power is on?
