s24 windscreen leak
STEVEDUNSTABLE
18 Aug 2008
Beds
sites.google.com
hi folks....any advice please on the best way to rectify the problom. the BAD leak is bottom right on the curve of the glass with minor leaks here n there.....what 2do ?????........1, just smother in mastic sealant ?....2, try and remove glass and start from scratch ?.....3, get new rubbers (is that poss?) .......4,...dont know !!!!! cheers all in hope !.....ps.in fairness to the screen, we were asking it to fend off some serious spray & rain while in the solent for the last 3 wknds so i suppose we should,nt be suprised......
Captain Tollys Creaping Crack Cure. Will solve the problem for the moment. If nothing else it will find the cracks for you. Keep putting a bit on, leave for half an hour, till it stops disapearing.
hlb's given the fix all solution - I'm in the same situation and have decided to try something more 'fundamental'; not lest because I have some obvious seal defamation.
yesterday I asked on PBO forum about a tool to realign the seals - but so far no response.
I had a leak from the starboard window on my S24, as HLB has said I used Creeping Crack cure and bought a surgical needle to inject it, that was several years ago a works a treat.
I wouldn't remove the window or the rubber as it will more than likely break into pieces (the rubber). What I have done is use Marine Black sealant and a bit of white spirit to make a neatish job. Have you checked the drain holes in the window frame, I had one blocked and the water started to back feed. I cleaned it out and used a hose pipe to flush it clear, I was amazed how much rubbish came out.
