Ryobi angle grinder - caution
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
Now the floating workshop has been launched, I seem to need two of everything.
I bought the cheapest angle grinder - Ryobi.
After six months periodic use, it started "stuttering".
The intermittent drive resulted in the disc fixing nut loosening with a consequent release of the cutting disc. A serious weapon capable of drawing blood if not amputations.
Opening the cover, the gearbox was full of shredded slivers. Both gears had badly worn teeth.
Exchanged at B&Q without question (for a different make).
Was it the cordless grinder? Mine has been in use for about three years but not very frequently. It seems to be solid still with no suggestion of a stutter.
It was corded and the reason for the stutter was the near-missing teeth on the gears. Occasionally, they came out of mesh and acted as a brake on the disc. Scary!
What size grinder? I have had a 230 /9" for over twelve years with no trouble and used frequently for heavy work.
Heavy beast too..
I had a Bosch model whose gear box failed - it had had heavy use. I had been using it to cut high tensile steel. I bought a cheap one from Costco as replacement - had no issues so far.
I think the Bosch one served me well - but I was not sure it was worth the money.
Jonathan
My first 100mm was a Bosch, in the 80s. Gears went, so I waited 3 weeks for fresh set...week later the windings burnt. Light dawned that I could buy a B&D pro 115 for the cost of the Bosch gears. The B&D was a far better tool and lasted for years.
The small angle grinders have a very small duty cycle (on time / off time) may be 5 to 10 %. so if I am doing heavy work I always use a big 2000 watt or more. The small ones range from 600 to about 900 watt so look at the power and not the make.
I have lost count of how many small angle grinders I have thrown away mostly by burning out.
Your gear issue is IMHO unusual with steel gears but I have had plastic gears brake often.
BTW Ryobi are just badge engineers so you cannot determine the quality.
My B&D lasted for almost 18 years catching fire on one occasion! The predecessor to the Ryobi was MacAlister which lasted around 8 years but I think needs new brushes.
The replacement was a De Walt. Unfortunately the inverter didn't like it, wouldn't power it did not even see it as a load. Other tools were ok.
Odd. Changed it for another McAlister which is fine.
The De Walt ran ok on "proper" mains.
Lesson:
When potentially dangerous machines show signs of not being in GWO, stop using them.
