mdonnelly
How can I measure output of this? Attached to 110aHr battery via a regulator but battery definately not being charged. Regulator shows that it is charging but battery is <12v. Any ideas? Thanks in advance, Mark.
In 10kts of wind, mine makes 0.1a. In 20kts it peaks at 1.0a.How can I measure output of this? Attached to 110aHr battery via a regulator but battery definately not being charged. Regulator shows that it is charging but battery is <12v. Any ideas? Thanks in advance, Mark.
If you've got the meter set to AMPS and you're measuring across the generator as you would while measuring VOLTS, then yes, you may stall the generator by effectively putting a short circuit across it.Have been trying multimeter but seems to stop the generator. Is this possible??
You cannot rely on that. They should be recharged if held in stock I think after 6 months but one I bought some years ago had clearly not been.The OP said his battery was new, so I assume it came charged
its a HRS 12v regulator. As Marlec recommend the 503 for batteries up to 100ah will connecting it to a 110ah battery make a significant difference?
