Rusty Stainless? Easy Fix!
limecc
10 May 2017
A few weeks ago I suggested using Dragons Breath fallout remover to clean a rust stained expansion tank and that seemed to work well. I found the stuff also works to clean up rusty stainless fittings. It's PH neutral, easy to source, why not give it a try a report back?
Oxalic Acid works well on horizontal surfaces as it has time to dissolve the rust (and stain). Its good to remove tannin stains on or near the waterline. On vertical surfaces it runs off too quickly, to react, and needs to be mixed with something (or bought already mixed with something) to allow it to cling and given time to react. Wall paper paste is one idea.
On a hull remember to wear safety glasses or goggles.
Jonathan
Fallout remover (decent quality) is amazing, i'll never be without it again.
Oxalic Acid is also amazing, for STAINS.
Fallout remover will remove actual rust / fallout build-up / rust build-up, Oxalic acid will just remove rust stains.
Both excellent, but for different applications.
Agreed. Someone sprayed us in hot cutting filings a few years ago. Piers with the Fleming had a similiar issue at the time. For about a tiny fraction of the cost and effort I gather from the job piers posted I got as good results as you could hope for.
Always use wallpaper paste with oxalic acid to do the Hull works a treat
An idiot in our sailing club volunteered to treat the club committee boat hull for me. I supplied the acid plus wallpaper paste. he duly applied all over but got fed up of work, so b..gered off & left it without telling me. Result was that paste went hard & it took a couple of days to get the b..y stuff off. Plus, the stains were still there, presumably because he put so much water in the oxalic crystals that they had no effect. :rolleyes:
What's "fallout remover"? Pardon my ignorance..
