Rusty mooring chain vs Shiny stainless deck fittings
Andy Cox
9 Oct 2018
Falmouth, Cornwall
This might be more applicable to us UK boaters, but I'm wondering what others here do when wanting to pick up a visitor berth and end up with a loop of really orrible rusty chain that then has to go through your nice shiny fairlead and onto a equally nice and shiny bollard or windlass?
I've done it once and was horrified at the damage the chain was doing to my nice shiny deck fittings:disgust: I've only anchored since then.
I was wondering about having a strop made up that has a snap shackle on one end and then comes up in a 'V', with each end of the V going through the fairlead and onto the bollard on each side of the foredeck.
Having pre rigged the strop on the foredeck, it's then just a matter of pulling up the chain and attaching the snap shackle whilst we potter ashore for lunch :encouragement:.
Andy
The same , just have a pre set L of mooring line already made up , with a loop for the bollard at one end and large chain hook at the other end .
It’s just long enough so any bow mooring chain is about 30 cm below the fairlead / boat / fibreglass.
Idea is to keep any chain off the boat just dangling off the bow .Seems to work .
Porto, would you use the same line if using your own anchor (i.e. snubber)? Also when you say 'bollard' do you mean windlass?
I assume this refers to a boat too long for the mooring and on pulling the lazy line you get chain?
I have never come across this in my 5-6 years in the med. It seems form the replies others come across it - would you not ask for a berth that fits?
+1.
Any marina which gives you a berth where you must pull the bow line up to its chain end doesn't deserve your money.
You Med guys are going off on a tangent:p
This situation has nothing to do with marina berths but relates to picking up a mooring, which is essentially a big rusty chain anchored on the sea floor, rising to a big float. There is then a short length of equally rusty chain with a loop in the end that you lift aboard and put over your bollard or windlass etc.
This type of mooring is prevalent in UK waters and is used either as a permanent seasonal home for your boat or for temporary visiting boats and is typically called a swinging mooring.
My original post was more to do with how to secure the boat without having to bring all that rusty chain on board. :encouragement:
Andy
Mean cleat but perhaps you can see why “ bollard “ is interchangeable on my boat .People ( guests of mixed boaty experiences) call them bollards .
Never use a snubber at anchor .Risk assessment dismissing them is based on the fasted possible up anchor and off .
The red is the made up stretchy loop, hook / carabiner yellow , chain blue for illustration to show its use .
Sorry no pic of the real contraption.
+1.
It’s all blame on Italians :)
Tnx MapisM :encouragement:
I used your “blue book “ reg doc for consistency so,s all the docs sing from the same hymn sheet in case we get a jobsworth doing our paperwork .
So I,am runing round in a 15 M boat with 13 M scrawled on a Brit laminated reg doc .
Picture the screen we arrive at a typical “ acceuil “ pontoon near a capitainerie I stay on board wife trots in bikini clad with the doc pack , they eyeball the written L ( and Beam which is correct ) and direct us to a berth .
Adding to the issue is the 42 badge , from 2004 same hull was badged 48 - more like it .
As regards “ doesn’t deserve your money “ well they charge for what’s written on the reg doc so basically under charge by 2 M every time :cool: That’s what they tap in to the system and photo copy .So when we return they call up the boat on the system and just want to eyeball a current insurance doc if there’s a que .
Nice problem to have tbo .
Andy
Really! Don't you put a rope through the loop on the top of the big float? I can't imagine anyone bringing chain on board - as you say it would cause significant damage in a short period of time.
This might help
A chain is used at the top as this is a very common way of keeping the boat in a permanent non marina situation and therefore it has to withstand adverse weather conditions (British summer) for prolonged periods of time and a rope strop probably wouldn't cut it with the insurers.
We're marina based, but it's an option when visiting somewhere and for whatever reason anchoring might not work.
Andy
