rajjes
Hi,
The mast of the new to me folkboat style boat, has 4 10mm halyards all of which go to the top of the mast.
I am assuming that one is the topping lift and the other 3 are halyards for Main, Jib and spinnaker.
Although it is clear that 2 face backwards (Main / topping lift) and 2 forward (Jib / Spinnaker), I am confused on which is which.
The difference lies in the way they exit the masthead as 2 pass over external pulleys hanging fore and aft of the masthead, while the other 2 pass through sheaves in the masthead unit. As this results in a different angle of the rope, I am concerned that attaching the incorrect sails might cause problems.
Am I correct to assume the following:
1 The Mainsail to the aft facing external pulley
2 The topping lift to the aft facing masthead sheave
3 The spinnaker to the forward external pulley
4 The Jib to the forward dacing masthead sheave.
Does this sound sensible or should say 1,2 be swapped?
