flykeith
Active Member
I am trying to figure how the runners on my cutter were set up. There are fixed wire stays from the mast ending in a fork, which I assume are then connected to wire strops which pass through a turning block on the deck, then aft to a flat (horizontal) deck block and then the Highfield lever. My problem is the wire strops I have are too long (even with the lever adjusted to its tightest position). I am only talking about a few inches too long, but I'm sure they should put some tension against the inner forestay. I assume (hope!) I don't have to add more wire and blocks to increase purchase.
Boat is Robert Clark 44'
Any thoughts?
Any thoughts?
