claymore
Last September I had a dry-mouthed moment when the rudder jammed - I'd been easing backwards out of a tricky corner in windy conditions and the pressure of water on the blade jammed it on full rudder. The forum suggested fitting stops and it seemed a good idea. I'm about to go and weigh the job up and am just thinking about the autopilot. I assume that I'll have to adjust the length of travel on the arm to the rudder or the pilot will be trying to push the rudder where it cannot go with stops fitted. I assume this will in turn burn out the motor/damage the hydraulic pump. Am I thinking clearly or imagining problems that won't exist?
Regards
John S
What care we - tho' white the Minch is,
What care we boys, for wind or weather?
Regards
John S
