rudder greaser
BOBBIN
4 May 2004
I have a grease nipple on the rudder stock of my Colvic Countess 33 on which the thread has worn and the nipple is now loose.
The steering, a Whitlock cable system, works well and there is no play in the rudder so I am looking for a simple solution to my problem.
I would normally tap out the existing hole in the s/s rudder tube and insert another nipple but the existing one is manufactured to fit a side on grease gun as there is insufficient room to use a standard "straight" gun. I have no idea where to source a replacement and would welcome suggestions as to the way forward.
........... the thread has worn and the nipple is now loose.
............................. the existing one is manufactured to fit a side on grease gun as there is insufficient room to use a standard "straight" gun. ............................
Go up a larger size and get a 45 deg or straight version as suggested by others
