Rudder bush dropped
If it were me I would put a bead of epoxy under the top hat/on top of the rudder blade. That would physically prevent it from dropping.
The bearing on mine is held in place with a set screw.
When I wanted to increase the gap between the rudder and the skeg I used a B&Q nylon tap washer which I split across on one side and wiggled into the gap. It's been there 4 years showing no wear. Perhaps that would work here.
