Rudder bearings
Tarka1
I am going to replace the rudder bearings on my Kelt 850 but am struggling to remove the phosphour bronze(?) fitting that fits on to the top of the rudder stock. I've removed the tiller which was bolted through the stock and the phos bronze fitting and I am now left with what looks like a stainless steel tapered pin holding the fitting to the stock. Question is, how do I get this pin out, after trying to "persuade" it with a big hammer and having no luck I'm now open to sensible suggestions.
A good pointed drift enabled me to get mine out. Make sure the pin is straight and not tapered so you know which way to drift it out. Don't be surprised if nothing moves after the pin is removed. Mine took weeks of soaking in penetrating oil and then plenty of heat to remove the fitting. Good luck.
Yoda
