Javelin
At the weekend my newish rudder bearings decided to seize to the shaft, so a lift out, investigation and cure will be found, again.
However when the bearings were acting as bearings, with free-ish easy movement at standstill, the tiller has always been heavy once underway.
The rudder is a semi balanced spade type.
I was wondering how I could lighten the load on the tiller given I cant increase the length of the tiller due to the main sheet traveler position.
I guess I could add an inch or two to the leading edge and fair to shape to increase the balance effect but what would be the downside of that?
Would it just want to turn more so I'd end up fighting to keep it straight.
In which case is the only option to reduce rudder area....
Or do I just have to accept that a 34' IOR design is just stuck with having a heavy helm.
