kgi
why is it the cat manufacturers insist on putting tiny rub rails on cats, they seem to use the same rub rail you would use on a run about, a small extrusion with a little bit of rubber in it, i know of two cats that sank from being caught against a wall when a bad squall came through. The fenders were flattened in the wind, once the boat started grinding up and down the wall thehull was quickly breached and then the deck "popped" off of the hulls and the hulls were crushed, it would appear that once that once there is a breach in this type of situation hull collapse happens quite quickly, so why aren't rub rails moulded in at the design stage, that way you basically have an external strake on which to mount a rubrail, the hull of the boat would also be further from the wall............what do you think?........keith
