Router for boat
Heckler
24 Feb 2003
My, not used now, relatively new Orange router is powered by a mains to 12v transformer. So, with some tweaking, it should be useable on board as a wireless provider of data? This idea is driven by the thought of squirting NMEA data wirelessly around the boat. I notice that digital yacht are doing something similar using TCP/IP.
Question for our IT geeks, this router has a USB port on it for sharing files, how could I feed NMEA in so that I could squirt it wirelessly?
Stu
gregcope
21 Aug 2004
Stu
Not sure it is as simple as using a USB input for NMEA when the USB port is expecting a block device (disk) to appear.
prv
29 Nov 2009
Southampton
Perhaps a rasberry pi? feed nmea to that then some black arts to feed by rj45 to the wireless?
Plausible, with the right knowledge and skills, but then you're mostly just using the router as a bulky and power-hungry wifi card. I'm sure there are any number of wifi adaptors for the Pi directly.
Heckler
24 Feb 2003
Point taken and I found this, http://www.maketecheasier.com/setup-wifi-on-raspberry-pi/
however I want a transmitter, not a rcvr
Was mulling with the idea of using serial to usb adapter, but would need some code for it to recognise nmea and retransmit it
Stu
prv
29 Nov 2009
Southampton
That doesn't make any sense. A wireless network is bidirectional, there's no such thing as a transmitter versus a receiver.
You'll need that regardless.
sailorbenji
20 Oct 2011
Depending on the complexity of your boat systems, you may want to look at transmitting NMEA over UDP rather than TCP/IP as this allows multiple listeners to the data.
Heckler
24 Feb 2003
Just reverse engineer the router then rewrite the firmware from scratch. It should keep you out of mischief for a couple of years.
ha ha! point im making, the router is designed to use the usb point to share files across a wireless network.
See the specs
WHAT'S INCLUDED
Features:
Remote assistance
Supports multiple devices
Secure - Wi-Fi Protected Access II (WPA2) to ensure your wireless connection is protected.
4 ports - Four 10/100 Mbps Ethernet ports for wired connectivity.
Personalised to the customer and exclusively for the EE network.
USB port for connecting other devices to your home network.
Sleek and compact design and it fits through your letterbox.
TECHNICAL SPECIFICATION
4 x 10/100 Mbps Ethernet ports.
1 USB 2.0 Host.
Support PPPoE, PPPoA, RFC1483 Bridge.
Traffic shaping (UBR/CBR/VBR).
OAM (I.610) F4/F5 support.
Wireless IEEE802.11b/g/n.
Wireless encapsulation WEP/WPA/WPA2.
Wireless QoS, WMM (Wi-Fi Multi media).
WiFi Protected Setup (WPS).
Supports up-to 300 Mbps data transfer.
So, software to share nmea stuff
S
BruceDanforth
13 Mar 2004
Tyne and Wear
This might be a start: http://www.stripydog.com/kplex/examples/piap.html
Not tried (or done more than skimmed over it) but it might give you some ideas. You'll probably need to hack it about a bit.
My boat is too low tech and too small to worry about wifi....off to grind off a bolt now.
No not a pi, an ipad. Digital yachts and others do apps that display ais amongst other things
S
BruceDanforth
13 Mar 2004
Tyne and Wear
You could skip the wifi dongle bit and use the orange router. Connect the pi with a network cable and let it get its network settings from the dhcp on the router.
prv
29 Nov 2009
Southampton
Wrong words
server? perhaps?
Alright, I'm being slightly facetious, but the point is that if you don't know this stuff inside out and backwards, with substantial experience of developing embedded firmware, you're not going to be able to make it do what you want. The fact that you have a piece of hardware with approximately the right connectors on it, does not mean you can simply set a couple of switches, download an app, and have speed and depth showing up on your iPad.
It's like someone who can't reliably tell one end of a spanner from the other, owns only a "B&Q My First Tool Kit", and lives in a terraced house with no drive or garage, saying "well, I have a car, it has an engine and wheels, and I can probably lay my hands on some wings somewhere. Why shouldn't I turn it into an aeroplane?"
