hollmanr
Hi, my fully battened main sail has round sail battens, rather then "flat" ones. The 2nd from the top is now broken so would like to replace it. The dimensions are 2 meters long with a diameter of 12mm. I can't seem to find any suppier who sells round sail battens. Does anyone know of a supplier who does ? I'm based in Ireland but European online shops should be OK. BTW I can't use flat battens as the pocket where the batten slides in (the pocket atatched to the sail slider) is only about 15mm wide. thanks !
