Eeyore
My Rotostay II has jammed (again!). Does anyone have a maintenance manual for the Rotostay II? I'm particularly interested in the top bearing assembly which consists of three pieces - two thrust faces and a ball race. One of the thrust faces has a smaller inside diameter than the other, yet both fit onto an un-tapered 20mm shaft and I want to know which way round the two faces should be installed. The bearing will go on either way without problems. I've searched the forum for others who experienced jamming furlers and most suggest the forestay unfurling within the foil to jam the system. This does not happen in the Rotostay II because the complete stay revolves with the foil, turning on top and bottom bearings.
