rope thickness, this should be a no brainer ...
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
i recently ordered 30m on line :) what i received was significantly thicker than i asked for and did not go through one of the fair leads, so
Genoa sheets, what i have, 10 years old, under a bit of tension measures 13mm diameter
its quite rough to touch, excellent
so, if it is now 13mm what was it to start with as i recon it will come in even steps 12 or 14 mm ?
i will want an eye spliced in
many thanks for your thoughts
If it is now 13mm I assume it started at 14mm, which I think is what I have. I use shiny stuff because it passes round the shroud rollers more easily but matt is traditional.
