We have chain/rope ground tackle. I don't really like rope/chain splices. What do others use? I have an "anchor shackle" but need a narrower one to easily pass thro the windlass deck plate. Suggestions please.
Out of interest what upsets you about rope/chain splices?
I've used them for yonks and other than the thickening aorund the join seem a perfectly reasonable (and simple enough for peeps like me to make them!) solution.
I suppose the answer is that the spliced rope takes a lot of wear and it can't be quickly disconnected from the chain without using a knife. On the other hand it will easily pass thro the deck plate. Would still prefer to eye splice onto an appropriate shackle which will pass round the gypsy.
Surely, the word 'quickly' implies that a knife is the quickest way. A serrated rescue/safety knife will go through most ropes like a hot knife through butter.
Having bought my current rode ready spliced this is what I have but the worry goes like this. With a rope splice (with a thimble eye and shackle) as I used to have, one effect of strain is to close the lay of the rope tightly around the tucked strands to increase the strength of the splice - or so I imagine. The unyielding chain cannot add a similar co-operative effect.
I hope that I shall never explore the ultimate extreme of the strength of my gear but is this a real concern or just a fallacy?
Rope construction relies on friction ... whether it be the lay-up, splice or knot.
The act of splicing to chain - the sheer length of the splice .... much longer than a "tucked" splice produces enough friction between the chain links and rope strands.
I have a rope to chain splice ... been there for many years ... in fact it will fail not due to lack of friction .... if I was to leave it long enough !! .... but due to corrosion ! A post a while ago commented on corrosion evident in such splices ... most likely due to entrapment of salts etc. and held against the galvanized metal etc. along with a nice amount of oxygen available to help it along ....
[/ QUOTE ] Agreed. And the easy run of the splice through the winch was a great advantage.
Chafe was the only issue that worried me. But with 70m of chain, that wasn't a threat that an annual inspection couldn't deal with. I ended up re-splicing every three years - more for my peace of mind than any logic. The splice always looked a little floppy . . .
It would be interesting to test a rope chain splice to destruction to see if the rope pulled out of the chain. I suspect a lot of splices rarely go in the water due to the length of the chain. But on a weight conscious multi we will use all the chain most times, with the added advantage of an automatic rope snubber.
I have used one on a lightweight kedge and noted the corrosion.
My splice could take the maximum tension I could apply with the genoa winch without any sign of slipping. No idea what that was (40.5ft LOA) but it had to be a few thousand pounds force, probably enough to drag the anchor!
