RogerRat
As per recent post last week, I said watch this space as I was about to trial a mod to the exhaust outlet.
The back of Panache is similar to all flybridges and I quickly came to the conclusion that they have similar characteristics to the rear of a 4x4 or an estate car. This means that a low pressure area of air behind the boat sucks any exhaust gases back behind the boat and some of the soot sticks and is a pain to clean off. /forums/images/graemlins/mad.gif
I took a closer look at what was happening to the airflow around the rear qtrs. and you can see quite clearly that the fastest moving air is moving past the side very fast when planing.
I thought it may be worth making up a fairing to expel the gases out further into the fast moving air. I acquired some thick 8mm latex (stiffish) rubber and cut a template to create and extension the the exhaust outlets. The rubber was red, so I antifouled it so it would look less like a pig with one ear.
This gave an extension of about 40-45mm further out and soon after it was fastened, I noticed that this fairing is standard on the Squadron. Hey I thought, this might work!
There was good news and bad, the starboard one fell off. /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
Sorry, a bit dark this morning.
The good news was that after a trip to Cowes and back, covering just over 30 miles, the Port side area was virtually clean and the starboard side smutty.
Realistically, the improvement was 90% ish, and the blessing was that by only having one fitted when we returned, I could see and compare the improvement.
MarkII will follow and when I've found the optimum, I may have it glassed in as permanent. The nice thing about a rubber extension is that if you do knock it when berthing it will just bend and not cause any other damage. /forums/images/graemlins/cool.gif
Not bad eh?
Not bad eh?
