Rod kicker question
BlueChip
24 Aug 2004
Bucks/Plymouth
I am just refitting my Selden gas strut rod kicker after having had the mast down for the winter
When I push the two sections together its as if the sliding part is coming up against a hard stop
I had expected there to be a little give and i wonder if something has jammed inside.
Even if I stand the pole vertically and hang on it there is no give (I weigh 15 stone)
Does this sound ok to you, if not what could be wrong?
malcp
29 May 2003
Chichester, UK
Don't worry. I had exactly the same experience some years ago when I took my mast down for the first time. You have to apply a larger force than you can apply by hand; you need to tighten the kicker or the mainsheet to compress it, ie something with a mechanical advantage. It does work. Just re-assemble and tighten up on the kicker.
robbieg
25 Sep 2003
Brixham/Midlands
Agreed. I had exactly the same experience-very suprised at the force needed to compress the kicker but it worked fine when back in place. Gave me some idea of the forces the kicker (& gooseneck) is subject to.
