petem
Fellow T34 owners will be familiar with the engine master switches that are placed below the helm seat bolster. They are connected to two relays and illuminate when the up switch is depressed. Well, that's what they are supposed to do but only one of mine illuminates.
Anyhow, the previous owner (-1) recently reminded me that the switches are very poorly placed as they are unguarded and can be accidentally switched off (they are immediately behind the skipper thigh). The symptom of this is that the impacted engine will start to hunt and the cause of this will not be apparent to the skipper. (I wonder if this might have been what caused the issue that one of my partners experienced in the summer that we attributed to fuel or slipping alternator belt.)
In light of the above (and because I like everything to be working on my boat) I have been investigating a fix.
I believe the switches are Carling V Series. You can find details here...
http://www.carlingtech.com/sites/default/files/documents/V-Series-IV-V-VII_datasheet.pdf
(JFM and other geeks will observe that they are Contura II actuators, unlike the dash that has Contura III actuators
V Series switches come in many different flavours and I believe a switch like this that drives a relay will be a (On)Off(On). The ( ) brackets mean momentary.
In addition, the switch needs to be illuminated (red). There are two different types of illumination; one type where the switch also illuminates the light, the other type where the switch is independently lit. I believe these switches have the latter. I think this is the exact model http://www.cactusnav.com/carling-series-contura-switch-only-back-light-p-15891.html.
So I'm wondering might be stopping my switch from illuminating. I suspect it could be one of the following...
1) Somebody has replaced the switch with the wrong type (unlit)
2) A loose connection at the switch end
3) A bulb failure
4) A loose connection at the relay end (I'm not sure where the relays are located)
So my question is, assuming the switch is independently illuminated, where does it get it's power from? Is it wired to the relay or the engine circuit (that is given power from the relay)?
This got me further thinking (dangerous I know). The two bilge pumps can be switched on by activating the float switches or the manual switches on the helm (both of which are illuminated). So I now wonder if the lights on the helm switches activate by the switch or whether they will illuminate independently (i.e. by activation of the float switch). Anyone know? If I had the wiring diagrams or access to the boat I'd be able to find out.
3) A bulb failure
