oldbasscat
New Member
Hey every one, I'm in need of some assistance. I have an older (70's model) Johnson motor and throttle controls. It was previously rewired to two rocker switches. The first was to activate neutral and the second was to activate forward and reverse. I blew the first switch and decided just to replace both with one three way switch, where center position would be neutral and up forward down reverse. But I'm not sure on how this needs to be done properly. I don't believe I need the ground any more because it was just to illuminate the lights on the previous switch. But I have two wires still to each switch. My load and supply. I figure I need to put both loads together and run it to my new switch as they are the battery, correct? And then simply put my forward to the top of the new switch and my reverse to the bottom. Does this sound correct? Any one can help please. I'm not the most educated when it comes to electronics on boats. Thanks
