RNSA 14 man
New Member
Does anyone have a plan of the RNSA 14 drop keel.? I need to replace mine as its no longer fit for due the dread corrosion.
Just a suggestion but could you not haul your old 'plate out and make a template from it? It may be slotted to fit over the pivot bolt so could be lifted out without removing the bolt?Does anyone have a plan of the RNSA 14 drop keel.? I need to replace mine as its no longer fit for due the dread corrosion.
Bill
Thanks for the idea. Unfortunately to the slot in the keel has opened out so much with due to corrosion, that I have no idea of its coJust a suggestion but could you not haul your old 'plate out and make a template from it? It may be slotted to fit over the pivot bolt so could be lifted out without removing the bolt?
correct dimensions anymore.Thanks for the idea. Unfortunately to the slot in the keel has opened out so much with due to corrosion, that I have no idea of its co
