Some of the bolts on the side handrail stanchion base plate fixing to the deck have come loose, there are four screws per base plate.
On most RLM 27's you can not get at the screws from inside the boat!
The bolts on my boat are about 90mm long and appear to screw into the solid GRP side fender extrusion.
Has anyone had the same problem and fix the problem alternativly any suggestions would be welcome before someone falls overboard!
