blackbeard
The topping lift on my boat passes over a block at the masthead, the block is supported from near the masthead by two pop rivets (about 4.5 mm dia) in shear.
As a topping lift, it seems fine. However:
a. the topping lift is the obvious thing to use as a safety line when going up the mast using the main halyard (it's a fractional rig so the jib and spinnaker halyards don't lead from far enough up). Is the "safety" real or illusory, ie would the rivets shear if they had to take my weight (as a shock load, of course!). (Not that much of a shock, I'm about 78 kg but my crew is about 50!). Do I need a safety line anyway, a tangle of safety precautions seems to attract unwanted events!
b. One possible answer to the man overboard recovery problem is to hang a 4 part purchase from about half-way along the boom. The boom thus supports the weight of a waterlogged person who could be a lot more than 78 kg; but the topping lift will only see about half this weight as it leads to the outboard end of the boom. Would the rivets be strong enough for this? or do I need another solution to the problem?
