Rinker drive ratio
Gsd
New Member
2 Aug 2014
Does anybody know the correct drive ratio for a 2002 rinker 270 with a mercruiser 5.7 250hp bravo 3
Probably 2.2-1 you can work it out if the drive is off or you can take the top off & count the teeth on the gears & work it out that way
If your stuck I can look up the no of teeth for the various ratios for you
Should be stamped in here
