co256
I have been looking into the subject of buoyancy and will share my findings with you...
What follows is a comparison of three types of rigid foam, the standard unit for comparison is 1 cubic metre.
2 part Polyurethane liquid weight 35 kg Buoyancy 950 kg Cost £216
Plastazote LD15 weight 15 kg Buoyancy 1000 kg Cost £473
Expanded Polystyrene weight 15 kg Buoyancy 900 kg Cost £91
There was an earlier post on this subject that suggested EPS (Expanded Polystyrene) absorbs water, I have found no evidence to suggest this, in fact quite the reverse. EPS does not absorb water but it will wick moisture to less than 4% of volume, rather like GRP.
It is recommended that buoyancy is retained in watertight compartments, spread evenly around the boat and as low down as possible within the hull canoe body.
