alpha
Hi all, hope you'll help...
I have a Freeman 32, which for the non-cognoscenti, has a half-wheelhouse of GRP sandwich construction. A previous owner fitted a vinyl headlining, which I am now removing (to the accompaniment of much expletive on acccount of the foul mixture of old adhesive, dried foam, etc, found beneath the vinyl!).
Now, when it is gone, I'll need to paint the fibreglass behind. Mostly, there is gelcoat; in some areas, the gelcoat is thin and the mat is just in evidence.
I need a paint which will look great, adhere to the existing surface (not easy to prepare it perfectly, though priming is a possibility), and repell moisture. I had thought of using Hammerite as it seems to stick happily to anything and keeps a good appearance, though I'm unsure about its predeliction for condensation.
Any ideas?
Any ideas?
