sebastiannr
Hi there,
On my passage from the Azores to North Spain the rubber mast collar fell out of the partners. I managed to get it back in but there is still a gap between the partners and the collar, which results in about 1cm of movement of the mast in the partners fore and aft- when the boat crashes into a wave, the mast bends forward under it's own momentum. It looks like silicon was poured into the gap between the mast and the partners, that doesn't seem like a proper solution to me. It's very disconcerting to see the mast moving around in the partners like that, is it a major problem? Do I need to fabricate a wedge of some kind?
Also regarding forestay tension: in heavy weather, when most of the genoa is rolled away, there is considerable bend in the forestay despite the backstay being fully tensioned. Is this acceptable or should there not be any bend in the forestay, ever?
Many thanks,
Seb.
Many thanks,
Seb.
